Want to add chapters to video (mkv, x265) files. Need chapters to precisely line up with keyframes to achieve smooth and instantaneous playback transition when skipping from chapter to chapter. Have been using mkvToolnix for this by alternating back and forth between the [Chapter Editor / Info Tool] tabs to manually determine keyframe timestamp closest to desired chapter start time.
As an example: say I want a chapter mark at 00:01:00. I check Info tool tab and scroll until I find nearest keyframe, which may be 00:01:04.271. Manually set that time as the chapter start point, then repeat the process for every chapter. This is a dreadfully slow and tedious process.
Is there any (freeware?) software that can either:
Automatically detect the nearest keyframe based on an approximate timestamp entry, and use that keyframe timestamp as the chapter start point
OR
Create a new keyframe at a point in the file based on a desired chapter start time
...or any other suggestions if you get what I'm trying to do and can think of a better way of doing it.
Thanks.
Thanks for the reply manono. Not sure I understand what you mean though... is there an option to automatically detect scene changes in mkvtoolnix?
While not free, VideoRedo will navigate directly to i-frames (press and hold the Ctrl key before pressing right or left arrows on keyboard). In that program, you can change the navigation behavior via the Preference settings. Perhaps mkvtoolnix has a preference setting as well.
I don't know as I don't use it. But it can't be too hard to know where you want to insert chapters (every so many minutes or at major changes in the story) and scroll to near that place to look for a scene change. When creating DVD chapters I find the scene change I want and set the chapter I want at the frame before and the chapter point gets set on the next frame - the one right after the scene change, which will be an I-frame.
VirtualDub2 can also find all the keyframes, at scene changes or otherwise.Last edited by manono; 13th Jun 2020 at 14:58.
Is there a software for editing Chapter markers in bulk?
By jooj in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2020, 08:13 -
[editing] easy switching between clips in VSDC or another free editor
By PawelK in forum EditingReplies: 5Last Post: 8th Sep 2019, 10:53 -
Looking for an EASY to use software for video editing
By Diana in forum Newbie / General discussionsReplies: 5Last Post: 29th Mar 2019, 15:27 -
ffmpeg, how to --enable-network --enable-protocol=tcp
By ramsh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jul 2017, 07:06 -
Easy Software for Archiving DV from Camera
By lukas_ch in forum Newbie / General discussionsReplies: 10Last Post: 21st Nov 2016, 22:24
